Slice in SynchroModeller
I am using Synchro Modeller and I would like to slice something but there is no slice icon on my Synchro Modeller. Where can I find the slice icon and when I slice it, is it gonna retain its properties? Thanks!
  • Hi Teresa,
    The slicing tool is available under Quantity Take-Off View
    In terms of properties, the splitted object(which becomes a parent) will retain all properties and the subdivisions(the children) will have new properties calculated by Modeller as in Area, Volume. i.e.:
    Best regards,
    Alex B.
