Title: Coffee Corner: SYNCHRO - Inspections Workflows - Batch Inspections CreationPresenters: Beth Buerger, Director of Product Management, Bentley Construction, Bentley Systems, Inc., Kevin Vivien, Product Manager I, Construction GTM, Construction, Bentley Systems, Inc, and Kerry Newbanks, Industry Solution Advisor, Construction Operations, Bentley Systems, Inc.Date: Wednesday, April 27, 2022Time: 10:00 AM Eastern Daylight Time
Register Now!
The SYNCHRO team has released additional functionality for their Field Inspections Workflows. They want to invite you to come see the new functionality! We’ll start with a 5 minutes overview on inspections then dive into the new items.
Batch InspectionsThis now means that a user can pre-populate their projects with inspections forms. This will automatically generate Inspection forms based on a project definitions
New Role based permissions
Multi-form WorkflowsSYNCHRO Inspections now has the ability to apply individual workflow assignments for multiple Inspection Types. Where previously Inspections were grouped under a single form type, the Forms Manager now allows multiple Inspection Types (Categories) with each type able to have its own workflow.
Forms ManagerThe Forms Manager has been turned on for this release and an Inspections tab has been added providing access to inspection form definitions. Through the Forms Manager the user now has the ability to edit form definition status as well as design features and workflows.
Homepage Work SummaryInspections has been added to the Work Summary section of the Homepage. In both the My Work and Project summary section Open Inspections is now listed.
Bentley SYNCHRO Coffee Corners are open to all Bentley users, free of charge. One learning unit is applied to each participant’s Bentley Transcript for self-reporting. To view prior sessions, watch the Recordings On-Demand.
**The webcast will be streamed through your computer, so there is no dial-in number. Please make sure your computer speakers (or headset) are turned on and the volume is set to an audible level so you can hear the presenters. Help
