Hi
When I import resource data into excel that contain 71000++ items, this error below appear.
Started: 2022-04-25 18:00Error: Columns in the [Resources] table do not match columns in additional table [Resources1]. Synchronization could not be completedFinished: 2022-04-25 18:00
The excel file is export from synchro, I understand that due to excel row limits, it's need to split to into 2 sheets. However, when imported back to synchro it's generate this error... Although I can import 2 sheet separately by create 2 file with 1 sheet delete. Is there another way to do it?
hi Edgar,
You can try, when export the table from SYNCHRO 4D Pro, use the xlsb format. this will support that 71000 line.
And you can use the same format to import back to SYNCHRO.
Indrawan
Answer Verified By: Jacqueline Chen
Thanks man it's work
