Hello. I have question in 3D Path/Keyframe
Hello.
My synchro program is weird.
'-nan(ind)' was created in the keyframe list to create the 3D Path.
It does not apply to 3D objects when moving or rotating the keyframe.
Only the front two of the keyframes can be modified, and the rest cannot be modified.
