Can we import models in Synchro Modeler? If so, how can I do it?
Thanks. I am aware of that, what I want to know is that in Navisworks there is a button called append data to add more additional models. I am curious if there is a feature that is similar to this in Synchro? because from what I learned, we need to add the model in Synchro Control and Synchronize it in order to be updated in Synchro Modeller, in which it takes too much time for us considering how big is the model that needs to be added. I am still learning in Synchro so forgive me if my questions are shallow :)
Hi Teresa - when you said "in which it takes too much time" , you are referring to 1) the time to upload these files to Control, and 2) the time processing the models through the iModel connectors, correct? What would be reasonable amount of time, in your opinion? You can let me know by giving me answer like: I have x models in the size of y mb, it should take no more than z minutes, or something similar.
yes, 1 & 2 are exactly my point. For example: I update some models and those models usually 5-9GB and it usually take a day in Synchro to update it in Control and iModel connectors.
