Hello,I am struck with creating resource groups by using multiple user fields in a single script.I would like to combine three user fields (Building section, building number and assembly code) and generate resource groups. I would also like to see the name of resource group corresponding to the user fields. Please see the desired result below
[B2]01.bouwdeel shows the building section. (Example: V)
[B2]01.bouwnummer shows the building number (Example: V04)
[B2]01.NL-sfb code shows the assembly code (21.12)I would like to create resource groups for each assembly code corresponding to the building section and building number.Desired result (Desired resource groups)V_V01_MetselwerkV_V02_MetselwerkV_V03_MetselwerkV_V04_Metselwerk...............Please find the image attached for your reference.I would be very happy to see a solution. Thanks in advance.
Best regards,Sujith Mahadevan
Hi Sujith,
Unfortunately, you cannot create a unique set of Resource Groups using SYNCHRO Scripts. The ideal process will be to use Excel -
Answer Verified By: Indrawan Wijaya
Second option... you can try this one:
RESOURCE ASSIGN_GROUP_BY_ID (UFV_ZERO("[B2]01.bouwdeel") +"_"+UFV_ZERO("[B2]01.bouwnummer")+"_"+UFV_ZERO("[B2]01.NL-sfb code") )
Indrawan
Answer Verified By: Arpit Prakash
Thanks Arpit. It is helpful to create and customise the groups easily
Dear Indrawan,Many thanks for the script. It helped me to create resource groups for the whole project in a single line.
