Hello,I am trying to "synchronize from" for the update of the model in spx format, but when selecting the configuration, and loading the model within synchro, it loses or does not recognize the assigned resources, Resource Groups, 3d filter etc, considering that the OIDs ( smartplant3d) are maintained.
In short, it is synchronized as if it were a new model and everything assigned is lost.
What configuration do you recommend to synchronize between synchro files?
I would appreciate any tip
Thank you
Hi Diego,
Have you tried the "Integrate" option in the synchronization window? Suggest trying that if you haven't already.
Paolomee
Hi Paolomee,
I already tried with "integrate", and the same thing happens, it does not take the update.
Diego
It may be best to send an email to synchrosupport@bentley.com. A Bentley colleague will reach out and will likely request the files.
Hi Diego, did you find the solution on this?. I'm currently having the same issue. Thanks.
Hi EG, yes i am find solution for "synchronize from", what is the modeling software are you using?
