Hola. Intento importar un archivo de Microstation a SYNCHRO 4D pro. pero no aparece toda la geometria. Solo aparece completa los compontentes ingresados a travez de celulas de la biblioteca de component center. La licencia no me deja descargar el plugin.
¿qué puedo hacer?
"I am trying to import a file from Microstation into SYNCHRO 4D pro. but not all geometry appears. Only the components entered through cells of the component center library appear complete. The license won't let me download the plugin."
Hello Las,
If you are using SYNCHRO 4D Pro v6.4+, we recommend using iTwin Connector iModel workflow through SYNCHRO Control. If using an older version and/or do not want to use SYNCHRO Control, please use SYNCHRO Plugin for Microstation - softwaredownloads.bentley.com/.../2917Here's additional information about these workflows - communities.bentley.com/.../choosing-between-synchro-4d-pro-importers-and-imodel-connections-to-add-3d-models
Thank you. I published it in i-model in synchro conrtol and that was the solution
Answer Verified By: Indrawan Wijaya
