We tried installing Version:06.05.01.05 but it couldn't Revit 2023.
Hello Djahanne,
SYNCHRO Plugins are not compatible with Autodesk 2023 products yet. However, we will likely have an iTwin Connector for Revit 2023 soon, which can be used to create an iModel in SYNCHRO Control.
Hello, we need to update the models to revit 2023 but the only problem is that there is no exporter plugin for synchro with revit 2023, so we cannot make the monthly deliveries to our client. Last year the same thing happened to us when we installed revit 2022, in the revit plugins folder we created a folder that said "2022" and inside it we pasted the installer and then the synchro exporter ribbon appeared in revit 2022. I mean:
I was able to use the Revit plugin for v6.2.1.3 from 2021 to 2022, by copying ExportSP.addin file from the following folder -
%ProgramData%\Autodesk\Revit\Addins\<year>
Any solution???
Hello Alejandra,
This process still works if you copy the add-in file from 2022 to 2023 folder, but you will first have to install the SYNCHRO plugin for installed Revit 2022. Also, do keep in mind that this is not an officially supported process.
Thanks a lot Arpit, it´s the solution we will use.
Hi Arpit
This method no longer work for Revit 2024, which I have copy from 2022 to 2024 Folder. Please help to expedit the dev.Thanks!
