Hai All,
In My Synchro 4D software in IFC settings. I tried to import the 3D Models from IFC . 3D Model surface should be changed / in rough / smoothness .Please suggest the solution.
Thank you.
Hi Ashwin,
Are you trying to change the smoothness of the IFC models? As in your screenshot, did you test the Increate Geometry Smoothness setting?
Can you send screenshots of what it's appearing as and what you expected it to be?
