How can I get the Synchro Open Viewer?
softwaredownloads.bentley.com/.../2812
Hi Prakash
I can not open your link or find the Synchro Open Viewer at the bentley store
Is the software still available?
Kind Regards
Manuel Krähenbühl
Project Engineer
If you are unable to access the above link, I recommend reaching out to your IT to give you access.
However, here's a temporary link that you can use to download the setup file - https://we.tl/t-myo5997JZu
Link is expired can you reshare it
hi Shahabaz,
You download from below link:
setupSynchroOpenViewer_x64_6.5.1.5
Indrawan
