I have Four Different Areas like A/ B /C /D. Each area has got different activities and schedules.
is it possible to export animation with 4 views with individual animations for each view
Hello Karthik,
If you want to show distinct schedule timelines for each Area, where the project start and finish are individually set for each 3d View, you will have to create separate Animations for each.
Hello Arpit, Thanks for your reply. I have a Common schedule for all four areas, Work will be done parallelly in all 4 areas. In this case, how to display it in a window? is this possible in Synchro?
In that case, open up multiple 3D Views, each having their own camera setup, which will then show up in Animation Export -
A few things to keep in mind -
Thank you Arprit, Just to check, do we have any material or video to refer to for setting up individual camera angles for each 3D View? or Just give me some high-level basics steps to follow? Thank you
Hope these help -
https://www.youtube.com/watch?v=5FAuqv2-wK8&list=PLwivaFFXYOsFrCnCUfMa9iYfD0SZYESOz&index=39
https://www.youtube.com/watch?v=yyW2zP7XsUA&list=PLwivaFFXYOsFrCnCUfMa9iYfD0SZYESOz&index=42
