Hello everyone, I am completely new here and was introduced to Synchro Pro this week.I was assigned to work on a project and I would have liked to listen to experienced people on how best to proceed.
I have a project, 12 different workplaces on that project and +-6 different contractors.The idea is that based on the schedule I now link all the contractors to the work zones so I can see by color which contractor is on which workplace.If the contractor needs more time we get a notification if the workplace is unavailable.Sometimes 2 different contractors can be working on the same job site.
What have I already tested out?- I have created the different work zones in revit and linked in via IFC.- I have created 'Profiles' of all the contractors.- I have linked the tasks to the zones and linked a profile of the contractor each time.
- I cant colorize 2 different contractors (profiles) to one workplace (object)
Hopefully someone can help me because I am completely new to this program.
Regards, Luis
Hey Luis,
There is no way to colorize 2 different Appearance Profiles on the same Resource, but you can explore other visual means of displaying similar information. Eg, Subdivide your Workspace into 6 parts representing a Contractor (grids/layers, etc), and as each Contractor becomes active in the Workspace, their respective color pops up.
Hi Arpit,
Thank you for your response.I will indeed have to look into splitting my work zones.a) is there an option to link the zones so that when the schedule is updated, the zones are also retained?b) will I also get a notification if my different contractors are working in the same work zone?
Thanks in advance!Greetings,Luis
What do i need.1) I need to create workspaces for different contractors2) I need to assign the contractors to the workspaces3) Sometimes it may be that one or more contractors will work on the same work area. 4) According to planning, it should be visible with colours, which contractor, is working in which work zone.
What should we be able to do with this?1) If the planning changes, all work zones would always be linked to the tasks with the contractor according to planning.2) If a contractor were to run late or need more time to carry out the works, we should be notified which work zones are 'at risk' according to the planning.
Luis,
Once you assign the Workspace to a Task, if the original modeled element is the same and not deleted/recreated, it will remain assigned regardless of planning changes.
There is no way of getting automated notifications for 'at risk' activities. Still, you can identify these tasks through User Fields values and set up Conditional Formatting for Tasks, or 3D View Color modes for better visibility.
