Cutting Plan
How to adjust the size of the Cutting Plane when enabled?
if I enable the cutting Plane, the plane occupies the entire model, or if I select "box around selected "the selected item only appears in the animation
I want to adjust the size of the cutting plan that occupies only a certain Area of the 3D Model and rest of the model remain undisturbed
