Good Morning Mr. Hay Mar Win ,A ) For Transparency Solution 1) If task & 3D Element not assigned but showing transparence mean follow below step,-Select the 3D Element > Right click and select the color options> Choose custom and change the Original Transparency (Untick/change value/standard)2) Check given Appearance Profile in Transparency setting. (If your task assigned)B) For 3D Element thinner.Conform once your modeling file in native software. Thanks.
Hi, maybe you could look into the setting of transparency in option as shown below, you can change the setting like Depth Peeling.
