Layout created from a private project is missing when uploaded to Synchro Control. Is there a workaround to keep the layout?.
Thank you.
hi EG,
If you get this issue. you can follow below 5 steps:
Indrawan
Answer Verified By: Arpit Prakash
The layout is missing when uploading and downloading from Synchro Control. Do we have to do these 5 steps every time we download the model from Control?.
Good question EG.
This is just the work around.
I also hope there a permanent fix in next realease.
A not so efficient workaround.
