1- Is there a way to show the task section from the gantt chart without the bar chart while exporting the animation.
Note: I can't use the Active Tasks as it does not show the dates next to each task.
2- How can I ensure that the opened 3d window will have the same window dimensions of the exported animation and are the same fit, without having to go back and forth between animation preview and the opened 3d window to zoom in and out until I get the right fit for the model. This happens most of the time when I have more than one window open.
3- What is the best way to show Planned Vs Actual as a single image animation on a specific date from more than one angle.
Exporting animations depends on both your software choice and project needs, with each step depending on their own particularities. Below are some general steps and considerations when exporting animations:
1. Select an Appropriate Format:
Determine the format you wish to export your animation in. Common options for exporting animation include MP4, MOV, AVI and GIF files - your decision may depend on what platform your animation will be shown (i.e. web, TV or cinema). 2. Set Resolution and Frame Rate:
Ascertain the desired resolution (1080p or 4K) and frame rate (24fps or 30fps). Achieve quality content may require higher resolution and frame rates that require additional storage space or processing power; but may lead to improved results with more storage available or additional processing power needed for production. 3. Configure Compression Settings:
If the format you have selected supports compression settings, configure them to strike an optimal balance between file size and quality. Different codecs (such as H.264/H.265) offer various compression options that could work for you.4. Export Settings:Navigating to the Export or Render settings within your animation software enables you to set your export options, such as file format, resolution, frame rate and compression options. 5. Set Output PathsChoose where and how to save the exported animation file on your computer, specifying both its filename and location.6. Export Options:Depending on the animation software you choose, additional export options such as audio settings (if your animation includes sound), alpha channel settings ( for transparent backgrounds), etc. may need to be taken into consideration before exporting your animations.
Commence rendering or exporting, depending on the complexity and length of your animation this could take time so be patient while monitoring its progress. 8. Preview Exported Animations:
Once the export process is complete, it is advisable to review the animation to ensure it matches your expectations. Be on the lookout for issues like missing frames or artifacts which could hinder performance.9. Save and Archive:It is critical that you keep multiple backup copies of both your animation project files and exported animations, in case any further edits need to be made or any issues arise with exported files.10. Distribution: Once your animation has been exported successfully, its distribution can be tailored to fit the goals of your project. This could involve uploading it to a website, posting it on social media channels such as YouTube and Facebook or submitting it for film festivals and other platforms.
Remember that the steps and options for exporting animations may depend on which software you're using; be sure to refer to your animation software's documentation or help resources for guidance regarding its specific export process.
