Hello Everyone,
When i am importing an equipment in Synchro 4D Pro, it is not appearing in proper scale/ size units. Is there any way to import it by specifying its units.
Hello Nayan,
Some of the equipment in our library may be in metric or imperial. If the scale is obviously off, you can scale the equipment directly in 4D Pro.
I will also encourage you to use 3D Warehouse for Sketchup, as they have tons of very good models for construction, and we can import native .skp models.
