Hi
I have some objects in my model which wont animate/follow the 3D path. I have tried adjusting the alignment (i,e centre/custom). Tried different types of 3D paths. I haven even tried to load the model into a fresh project and create new tasks but still no luck. It is bathroom pods which I want to show dropping from the sky. Slabs and precast planks all work as they should. Columns seem to be temperamental too. Some will animate and some wont. Any ideas?
Stephen
An update on this, If I convert the object to 'parts' in Revit an re-export. It then works with animation. I have a lot of these objects and thats not really the workaround I want.
Furthermore, If I export the model to dwfx (rather than using the .spx exporter) the same objects are able to be animated.
hi Stephen,
What SYNCHRO build that you are using? If you are not using 6.5.2 yet, you can do a small testing.
Because I see our new released 4D Pro, have some improvement on the 3D Object that are not working normally from Revit.
Please check this release announcement.
SYNCHRO 4D Pro 2023 (v6.5.2) release announcement
Best regards,
Indrawan
