Can I use iTwin Synchronizer v1.1.30 to sync imodels from AutoCAD, Civil 3D & Revit? If yes, what version it supports?
TIA
Once downloaded iTwin Synchronizer will auto update to the latest version of iTwin Synchronizer and iTwin Synchronizer will also automatically download the relevant bridges to run the selected files. It will run a wide range of dwg and revit versions. In iTwin Sync go to Help>About and it will show what type of Conversions it can use.
Hi Joey,
I assume it's not information what Mark asked for.
The current iModel Bridges versions can be easily checked in iTwin Synchronizer, similarly to the list you provided:
But I think Mark asked what original applications versions (or file versions) are supported.
It's very good question in my opinion, because the bridges installations do not contain even basic readme.txt file :-( and also iModel Bridges Wiki does not provide any helpful information (Geo Bridge providing SHP format support is the only bridge described).
E.g. there is new Civil3D version released every year, but often they are not compatible (because using different Civil 3D Object). When talking about Civil3d Bridge, it's not clear whether it supports all versions, the latest one only or some combination.
To say "It will run a wide range of dwg and revit versions." cannot be accepted as a real answer for any serious Synchronizer implementation in real project. It's like to say "This bridge will withstand a wide range of load" ... probably such information will be not enough to build such bridge. Precise numbers and exact facts are required ;-)
Maybe Dan Eng can provide some details?
With regards,
Jan
Hi Jan and Mark,
The DWG files are currently being processed by the MicroStation iModel Bridge. Let me try to put together a listing of which iModel Bridge supports which respective file format and version. Once I have that, I'll reply back so that it is listed here. Thank for bringing up this topic. It will certainly be helpful to everyone.
Dan
Hi Mark,
As a follow up, here is a table of current file formats that we support and versions. I'll add this as a part of our wiki and keep it updated to the best as we can with the most up to date information at the moment. I hope this helps.
iModel Bridge
