Projectwise 365 - design review - Difference between imodels creations
I noticed that when using Projectwise 365 Design review, the I-model created inside Projectwise 365 document are not as good or working as well as those created from the I-Twin desktop platform.
For exemple: custom linetypes won't be read properly, civil files won't be recognise (even if the good connector is use)
I just hope that you are going to update the web platform to be as good as the desktop one and not the opposite...
  • Hi Interesting and very valid point.
    As you can imagine the "web" version has no access to your machine so any custom items (including local materials) are not available and therefore will need to be added to a managed workspace.
    For the desktop app, it has access to everything.
    Therefore the web app will never have access to local files.  We are looking to enable more files to be made available, but how that experience will be is yet to be defined and as such for local (custom) types, the web application will always be lagging.
Reply
