I-twin synchronizer app, very very slow
I just installed the Itwin Synchroniser app, it's so slow! any model, even an empty one takes forever to synch.  Is there anyplan to make the process faster?
  • Hi Jeremie, what do you mean by "slow".  The main factors are
    1 : How long it takes to determine the type of document ... dgn it has to check all connectors, so ensure they are all downloaded and available
    2 : How slow your connection to iModelHub is  : Ensure your project is local ... ie if your project is US based and you are in the UK that will impact performance
    3 : The size of the base models ... generally I always run the connectors locally so I am not waiting in queues and do not see a performance issue on my machines.
    Can you define where the slowness is .. ie loading the models / determining affinity / downloading connectors ?
