Could someone point me to the correct property name for Levels for Revit generated iModel graphical elements. For elements generated from Bentley software this is captured using the LEVELNAME property in each BuildingDataGroup Class. However this is not included or exposed in each Bentley_Revit_Connector_Schema class. If it is not exposed then is their a base property for levels in the biscore schema.
Many Thanks
Hi Simon, not sure if this is related to iTwin, if it is then bis.category holds the levels and you can use select * from bis.geometricelement3d to show all geometric elements and link on category.idselect e.ecinstanceid, e.ecclassid, e.userlabel, ca.codevalue from bis.geometricelement3d e join bis.category ca on e.category.id = ca.ecinstanceidShoudl give you the "level" names of any geoemetric elements, regardelss if they are revit or IFCDoes that help ?
I wasn't sure if this was the right forum but thanks for the answer - i was struggling with the base classes for elements within the imodels - i have the reporting working now using the codevalue property
