Hi all,
I have some BCF files i am trying to import into Issue Resolution to be accessed inside a iModel. We are repeatedly getting errors getting this to import - is there a special Form or setup required to avoid import errors?
Mark
OpenRoads Designer 2021 R2 (10.10) | Microstation CE Update 16.2 | ProjectWise CE 3.4
HI Mark, if you start by exporting an issue from the Issue Resolution Service to BCF it will show you the format that it is expecting on import.
Hi Dan,
Exporting out a BCF and attempting to reimport it results in the same BCF import error.
Hi Mark, following our chat outside this forum, the file you provided was 82MB. We handle BCF files of up to 30 MB in size. It is recommended to split down larger files.
Hi Andrey, these are BIM review/comments from our state road authority and very unlikely to get smaller file sizes. Is there an enhancement planned to support larger BCF file import?
Hi Mark, it is something that can be considered. Would you mind adding your feedback here ProjectWise Forms (aha.io) at all?
