I am looking to set up a suppression rule in the iTwin Clash Detection tests for the test to ignore all Public Health Pipework that is 100mm Diameter and smaller. These pipes penetrate architectural and structural walls but do not require and opening as they will be drilled in on site so therefore is not a clash
Is this possible?
Hi Lourens, I believe this has now been resolved.
Can you confirm ?
Glen,
Yes - thank you very much for your help. We can now add a supression rule from the standard set of surpession rules to ignore all pipes smaller than a specific diameter.
