Using Mstn, the user can synch changes to and from the imodel, once it is attached as a Ref file.
Is this bi-directional synchronization available for Revit?
This is an example of bi-directional synch between Rhino and Revit.
Also wondering if this will be possible using Nvidia Omniverse.
Hi Dominic, Autodesk are more than welcome to reference in an iTwin. This would be an Autodesk request though, not a Bentley request.Autodesk have access to the iTwin structure, and we would of course offer any support to enable this.
Hi Glen,
Sure. But I don't think they will be too interested.
I doubt McNeel got much support from Autodesk when they tunnelled into Revit using Rhino.Inside... displacing Dynamo?
A number of initiatives for synchronisation across apps: Rhino.Inside, Speckle, Omniverse..
Maybe the ODA will step in here and add bi-directional synching to its BIMrv API. I think Graebert already offers .rvt import and updates. 2m dwg clone seats. I suspect in a few years this will be the norm for dwg editors. ODA seems to be setting itself up to be an interop hub with APIs for rvt, ifc, dwg and pdf. t would be a shame for Bentley itwins.js to fall behind the curve here.
