I created a 3D model through Context Capture as a drone image file without geographic information.
Should connect to the iModel of SYNCHRO Control via Context Share Function.
In this case, I wonder how the 3D model made through Context Capture and the model in SYNCHRO Control are mapping method.
Because the 3D model made through Context Capture doesn't have geograhic information and the iModel has geograhic information.
Hi, you can "reference" the context capture into a Microstation session and then publish the model and that should geo-reference the context capture, otherwise you need to geo-reference the context capture model with contextcapture tools
