Hi,I have some issues maybe someone else used to deal with. 1. The first is that deleting existing connection from iModel fails and unwanted files remain in model2. I have created connection with .dgn file (165MB) which went successful but it doesn't appear in selection tree in iModel Hub3. Are named versions possible to delete or the only way is to hide them?Thanks in advance
Dawid
Dawid Jarka said:1. The first is that deleting existing connection from iModel fails and unwanted files remain in model
When the connection was deleted what type of delete was selected?
https://communities.bentley.com/products/digital-twin-cloud-services/itwin-services/w/synchronization-wiki/53100/delete-a-connection
Dawid Jarka said:2. I have created connection with .dgn file (165MB) which went successful but it doesn't appear in selection tree in iModel Hub
Was a named version created after the sync on a change value with "Finalization changes"?
Dawid Jarka said:3. Are named versions possible to delete or the only way is to hide them?
Only Hide option is available at this time
Hi Joey,Thanks for the reply. See mine below1. I wanted to delete all synch data but at the end I still have file available in iModel Hub. 2. I have done one more test. Two new named versions were created. First with DGN and the second with NWC. At the end only the second one shows up in iModel Hub tree. DGN file is 3D3. OkRegardsDawid
