Hi all,
We are getting the error below trying the sync a Navisworks models into iTwin. This same model has been syncing fine for months (synched weekly) and has only started throwing up this error recently.
Has anyone else experienced this?
Hi Mark,
Can you try again please? This could be an instance of multiple people trying to sync something at the same time and the exact timing causing this problem.
If it happens again, please submit an SR and add the logs by clicking on the gears of the iTwin Synchronizer to zip up the logs.
Tim
