I'm having the following problem creating an iTwin viewer: When following the tutorial, when executing the 'npm start' command, this message always appears. the system cannot find the 'package.json' file. But this file is there instead.
Em anexo o arquivo '.log'
0 verbose cli C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js 1 info using npm@8.11.0 2 info using node@v16.16.0 3 timing npm:load:whichnode Completed in 0ms 4 timing config:load:defaults Completed in 1ms 5 timing config:load:file:C:\Program Files\nodejs\node_modules\npm\npmrc Completed in 2ms 6 timing config:load:builtin Completed in 2ms 7 timing config:load:cli Completed in 2ms 8 timing config:load:env Completed in 0ms 9 timing config:load:file:C:\Users\Davi Pessoa Ferraz\Visualizadores\.npmrc Completed in 0ms 10 timing config:load:project Completed in 4ms 11 timing config:load:file:C:\Users\Davi Pessoa Ferraz\.npmrc Completed in 0ms 12 timing config:load:user Completed in 0ms 13 timing config:load:file:C:\Users\Davi Pessoa Ferraz\AppData\Roaming\npm\etc\npmrc Completed in 0ms 14 timing config:load:global Completed in 0ms 15 timing config:load:validate Completed in 1ms 16 timing config:load:credentials Completed in 0ms 17 timing config:load:setEnvs Completed in 1ms 18 timing config:load Completed in 11ms 19 timing npm:load:configload Completed in 12ms 20 timing npm:load:mkdirpcache Completed in 1ms 21 timing npm:load:mkdirplogs Completed in 0ms 22 verbose title npm start 23 verbose argv "start" 24 timing npm:load:setTitle Completed in 0ms 25 timing config:load:flatten Completed in 3ms 26 timing npm:load:display Completed in 4ms 27 verbose logfile logs-max:10 dir:C:\Users\Davi Pessoa Ferraz\AppData\Local\npm-cache\_logs 28 verbose logfile C:\Users\Davi Pessoa Ferraz\AppData\Local\npm-cache\_logs\2022-07-18T14_28_48_614Z-debug-0.log 29 timing npm:load:logFile Completed in 6ms 30 timing npm:load:timers Completed in 0ms 31 timing npm:load:configScope Completed in 0ms 32 timing npm:load Completed in 24ms 33 silly logfile start cleaning logs, removing 2 files 34 timing command:run-script Completed in 3ms 35 timing command:start Completed in 9ms 36 verbose stack Error: ENOENT: no such file or directory, open 'C:\Users\Davi Pessoa Ferraz\Visualizadores\package.json' 37 verbose cwd C:\Users\Davi Pessoa Ferraz\Visualizadores 38 verbose Windows_NT 10.0.19044 39 verbose node v16.16.0 40 verbose npm v8.11.0 41 error code ENOENT 42 error syscall open 43 error path C:\Users\Davi Pessoa Ferraz\Visualizadores/package.json 44 error errno -4058 45 error enoent ENOENT: no such file or directory, open 'C:\Users\Davi Pessoa Ferraz\Visualizadores\package.json' 46 error enoent This is related to npm not being able to find a file. 46 error enoent 47 verbose exit -4058 48 timing npm Completed in 49ms 49 verbose code -4058 50 error A complete log of this run can be found in: 50 error C:\Users\Davi Pessoa Ferraz\AppData\Local\npm-cache\_logs\2022-07-18T14_28_48_614Z-debug-0.log
Can anyone help me with this?
can you try npm run start
Same error. 'Cannot find package.json file.' But the file is there and I can view it.
Hi DaviPF,
Check whether npm is installed properly or not.
Try checking in cmd npm version.
Hi, Hope this helps.
