Why am I getting trapezoidal shape instead of just line in the 2 point cross section option,? shape changes as we pan through.
The camera option is turned on causing everything to display as a perspective view and distorting the 2 point rectangle. Turning off the camera would cause it to display as a rectangle.
The example below shows the same view with the camera on and off. The amount of distortion will change depending on the view angel and size of 2 Point rectangle.
You just smashed it Joey. thanks a lot for swift support. it is working as expected now.
