Is GetFeatureInfo supported for WMS layers?When I hover with cursor it seems to show a table but it is unreadable.
Hi Otto,unfortunately that is an issue with the styling we use. If you switch back to light mode you will see that the table contents are filled in. The data is there, just the styling for dark mode makes it unreadable.
Thanks. Seems so as was able to see it on other machine.
Now we need to have ArcGIS REST API for search.
