I upload Model.imodel file while creating iModel in iTwin Platform by following this link "developer.bentley.com/.../"
1) if I upload .dgn file it showing only white mesh 3d model in iModelHub. whenever i created viewed version manually in that iModeHub then only it is showing white mesh in design view.
so that, we want to see that whole textured 3d model as same as in context capture viewer tool.
2) if i upload model.imodel file format it doesn't show any thing in the imodelHub . it is showing there are no Named versions created.
how to create named versions while converting .imodel in context capture editior tool. and we should see the whole textured 3D model.
Issues with the developer platform should be directed to their GitHub or StackOverflow areas.
https://github.com/iTwin/itwinjs-core/discussions
https://stackoverflow.com/questions/ask?tags=bentley-itwin
The likely issue here is for "1)" the create sample iModel probably does not have the the ability to upload the terrain model to a context capture source. And for "2)" .imodel files are not a directly supported file format as outlined here:
https://communities.bentley.com/products/digital-twin-cloud-services/itwin-services/w/synchronization-wiki/47595/supported-applications-and-file-formats#:~:text=Presently%2C%20Shapefile%2C%20PostGIS%20database%2C,Spatial%20database%20formats%20are%20supported.
How to work with file types, which use the MicroStation Connector?
Import file to MicroStation design file and save. Use the DGN file for converting it into the iModel.
Note for .imodel files, they must be referenced into a DGN file and then an i.dgn must be produced in order for the model to be imported with the MicroStation Connector. Support for .imodel 1.5 and 1.6 versions will be dropped with MicroStation CONNECT Edition Update 17.
