I have tried several times but always get stuck on the "Cleaning up" portion of the sync process. I have tried using brand new imodels in the hub and have let it run all night.
Imodel hub does show the change sets. so I am not sure what its hung on.
We'll get in touch to ask for your log files to try to diagnose this, and can follow up on this thread.
Based on the logs Kris was able to provide, this seems to be caused by network issues communicating with the iModel Hub. The development team is discussing ways to better diagnose and present this in the interface.
Closing the loop on this thread. The issue I was facing was found to be due to having Windows 7 on the machines. I have tested on multiple windows 10 machines without issue.
Answer Verified By: Kris Wishart
