as a part of learning ProjectWise 365 and iTwins ecosystem, I am trying to create iModel using iTwin Synchronizer,
Everything seems to be fine (project is created, empty i-model is created, everything is recognized by installed synchronizer), but regardless I try to add .dgn or .dwg, I always end with:
But the bridges for .dgn (MicroStation) and .dwg (civil / civil 3d) are installed already:
I ensured I have all necessary privileges: Because I am BDN member (I played with iModelJS source code already ;-) and I have all roles assigned both at general and project level, I assume this part should be fine.
Attached are iTwin Synchronizer log files. Windows 10 with all updates and patches installed, Czech GUI and local used.
BTW From log files, it seems Squirel tries to access MS Team. Why?
With regards,
Jan
iTwinSynchronizer Diagnostics 2020-04-20T05-17-47.362Z.zip
I tested the workflow with 1.0.112, unfortunately the bug still exists.
Unfortunately the error is not in the iTwin Synchronizer, so it will take another coupe days to get it all the way through the system.
Answer Verified By: Jan Šlegr
Hi Jeff,
Jeff Marker said:so it will take another coupe days to get it all the way through the system.
I confirm that the version 1.0.126 solves the problem, bridge for DGN file (specifically it's MicroStation 2.1.0.276) is now found.
But another problem exists, it's described in my new post.
