[1.0.126] Synchronization stopped
I am trying new version iTwin Synchronizer 1.0.126.
It seems this version solves reported issue with not found iBridge, but it still does not work fine.
I am able to define synchronization job (define folder, choose DGN file, proper iBridge for DGN file found), but when I try to start synchronization, error is reported with information "Synchronization stopped".
The file with logs is attached. I found in Summary.txt information that iModelBridgeFwk.exe command line failed, but I am not able to analyze, where the problem is.
With regards,
  Jan
iTwinSynchronizer Diagnostics 2020-05-04T05-13-22.512Z.zip
