iTwin Synchronizer - Latest Version and Notes Listing
Please refer to the following table for the latest build version and build notes.
Date Version Notes
9/22/2022 1.1.353
Resolved Connector download issue introduced by Antivirus, Reduced size of installer, Internal fixes
7/26/2022 1.1.331
Windows 11 Support, Internal Fixes
6/7/2022 1.1.321
Unmap Feature, ConceptStation Connector Support, WorkSpace Picker for OBD and ProStructures, Internal Fixes
3/31/2022 1.1.301
Badgers Updates, Integration test, Delta Package, Internal Fixes
2/11/2022 1.1.283
Internal Fixes
1/31/2022 1.1.279
Badgers Report, Electron Forge Migration, iModelJS package Updates
11/19/2021 1.1.258
Internal Fixes
11/8/2021 1.1.256
Installer is Digitally Signed, Internal Fixes
10/30/2021 1.1.254
Internal Fixes
10/22/2021 1.1.251
Internal Fixes
10/5/2021 1.1.244
UI Migration, Internal Fixes
9/20/2021 1.1.239
Internal Fixes
9/16/2021 1.1.237
Added Digital Signature to Exe, App Insights, Internal Fixes
8/27/2021 1.1.229
Internal Fixes
8/13/2021 1.1.225
Internal Fixes
8/9/2021 1.1.224
Internal Fixes
8/3/2021 1.1.222
Internal Fixes
7/1/2021 1.1.212
UI changes for Projects having no connection, Internal Fixes, Added iModeljs Logging
6/17/2021 1.1.208
Internal Fixes
6/7/2021 1.1.205
Connector Background update and Inline Progress, Internal Fixes
6/2/2021 1.1.204
Internal Fixes
5/25/2021 1.1.201
Internal Fixes
5/17/2021 1.1.198
Connectors Delta updates, Internal Fixes
4/2/2021 1.1.178
Internal Fixes
3/25/2021 1.1.174
Internal Fixes
3/12/2021 1.1.168
Internal Fixes
2/26/2021 1.1.161
Internal Fixes
2/19/2021 1.1.159
Connector list is in separate menu "iModel Connectors", Added options for stale file processing, Internal Fixes for performance improvement
2/1/2021 1.1.150
Version Number Fix in About Section, Internal Performance Fix.
1/18/2021 1.1.141
iModel Connector and About Section Split, Tooltip changes and Internal Fixes
12/18/2020 1.1.129
Addressed file search path limitations for iTwin Design Review Sessions
12/10/2020 1.1.124
Internal Fixes
12/4/2020 1.1.121
Fixes for Stale File Processing and Some internal Fixes
11/12/2020 1.1.112
Internal Fixes
10/29/2020 1.1.101
Internal Fixes for listing Bridge Issues at the end of Successful job run
10/27/2020 1.1.99
Added support for "ESRI file geodatabase" directory mapping.
10/15/2020 1.1.93
Internal Fixes for File Search Path patch fixes
10/1/2020 1.1.88
Internal Fixes
9/24/2020 1.1.82
Internal Fixes includes PowerPlatform support for ITDR sessions.
9/3/2020 1.1.75
Internal Fixes
8/24/2020 1.1.72
Support for locationzation for locales with '-' in their name (e.g 'zh-cn)'
Support for using input files on mapped network drives
Caching of remote bridge metadata for faster queries
8/20/2020 1.1.69 Internal Fixes
8/11/2020 1.1.65 Internal Fixes for processing i.dgn files
8/6/2020 1.1.62 Internal Fixes
7/16/2020 1.1.50 Refreshed UI components for easier identification. Improved messaging for when iModel Bridges need to be Enable for synchronization. internal fixes.
7/9/2020 1.1.48 Internal fixes
6/25/2020 1.1.37 Improved messaging if reference files are detected outside of the search path. Internal fixes.
6/18/2020 1.1.30 Internal fixes
6/15/2020 1.1.22 Support for the Open Buildings Designer iModel Bridge
6/8/2020 1.1.16 Internal fixes
5/21/2020 1.0.146
Support for PlantSight SPPID iModel Bridge
Support for Geo iModel Bridge
Resolves an issue with Updating multiple iModel Bridges at the the same time
Supports non-English Named View names
5/14/2020 1.0.140
Improved messaging in the event there is an error when processing a Synchronization
5/4/2020 1.0.126
View Incoming changes to the iModel since the last time you had synchronized your local file(s).  This can be viewed by the expanded section called "Previous Changes" on the "Synchronize your Changes" page.
This build resolves an issue where non-ASCII Characters would prevent an iModel Bridges to be run, if those characters were present in the user name.
4/16/2020 1.0.106
Internal Fixes
4/3/2020 1.0.92
The About dialog now displays information regarding which iModel Bridges are enabled
Resolved an issue with popup dialog size during synchronization preventing viewing of issues
Resolved issue where the iModel Bridge would be listed multiple times in the list of enabled iModel Bridges
Resolved an issue where creating a new Synchronization prevented the MicroStation iModel Bridge from continuing to process without an restart to the iTwin Synchronizer
