may I ask for an analysis and insight what exactly happened and why the synchronization failed?
Initial situation:
Synchronization defined in iTwinSynchronizer
First synchronization job configuration:
Problem description:
When I tried the synchronization again, it fails also.
With regards,
Jan
iTwinSynchronizer Diagnostics 2020-07-17T05-10-23.030Z.zip
synchronized-files.zip
The short answer is that the MicroStation bridge crashed in the middle of the conversion. Unfortunately, a recent App bug is preventing the bridge from uploading its crash reports, so we'll try to reproduce to find out more.
The only difference from another iModel in the same project, that has no problem with the synchronization, is that the discussed one has extent defined and also dgn model gcs assigned.
