I have a roadway model master dgn file with all together 52 reference dgn files and some (24) raster images. The design team is using and updating the dgn components on ProjectWise, storing them in multiple folders, so the reference files are not always in the same location as the master. I have watched the video about Best Practices for Creating a Civil iModel to understand how to publish my master file to the iModel Hub. The video is explaining how to publish the models from an extra created 2D container file using the downloaded offline reference files and the iTwin Synchronizer app. Since the project is already on ProjectWise we would like to utilize the iTwin Synchronizer Portal by creating new connection to iTwins using the ProjectWise Web as a data source.
After establishing the connection, selecting the master file and initiating the sync workflow, it is always failing. Probably because the master file isn't setup exactly the way how the iTwin bridges could read it, but it is setup to support the design process itself and the way how the engineers are working and using the files.Is there a way to publish any type of master files from ProjectWise Web as they are set together without to modify them, or create offline replicas?
Thank you!
Hi Pal ... can you advise which project this is defined on.We would need to know the exact failure messageHowever, it could be that you are processing the models with the wrong type of connectorCurrently this needs to manually assigned for each application, unless you are on a specific project that has the affinity capability enabled.
I have selected the civil bridge to process the file, since the model was set up in ORD for roadway design. The model master contains although other raster image files too as references. The sync status indicates that all files have been failed. In the sync report it show 988 files have been processed, without any failures.
Hi Pal,
Did you end up resolving this issue as I am experiencing the same issue with ORD synched from ProjectWise. I had no issues with this workflow up until recently.
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation CE Update 17.2 | ProjectWise CE 3.4
Hi Mark, no, not yet. Bentley is actually looking into this. No feedback yet.
