HI all,
firstly I apologize if this question is asked in a wrong community.
I have project in Revit, stored on ProjectWise and I am using ProjectsWise integration for central file and worksharing. In this project I have one other Revit file linked - directly from ProjectWise.
If I check Show References in ProjectWise Explorer it is all correct.
My problem is. When I publish this Revit project into i-model, I can see the Revit link listed in model tree, but i cannot see the geometry from that linked file.
Is there any way how to see those Revit links, without them being mapped directly to the imodel?
Thanks.
Lukas
This is a limitation with the Revit connector. The Revit Connector cannot pull the linked file from a Revit file. Each Revit file needs to to be mapped for the data to pushed to the iModel.
