We are running into synchronization failures such as this:
How do we solve issues like this?
Justin
Hi Justin,
it's only a guess:
The first error happens when EC data in DGN file is based on external schema EC schema, but is converted / synchronized in environment where this schema does not exist. Without EC schema, a structure of EC data is not known and the data cannot be converted. A solution is to add missing schema to the synchronization system (which I am not sure whether can be done by a used in your case).
The second issue is opposite case: EC schema exists, but exists in more versions. It can happen in situations like:
From the message it looks like it's the third case. A solution is to check EC schemas version(s) and to ensure they are the same.
With regards,
Jan
Эта ситуация вызвана использованием схем разных версий. У меня такая ситуация возникла при публикации файлов OPM v7, а затем публикация файлов BRCM v9. Сейчас SR обрабатывается
Hi Andrey,
please respect this is international community, where English language is used. I think it's not so big problem to use Google or Bing translator to follow this rule.
