I am creating my first iModel but I have a problem because i feel that the models are uploading VERY slowly. Is this normal? I want to start using iTwin instead of NavisWorks but if this is the normal speed of making changes in the iModel i dont know if its doable.
iModel sync
Size of files
I'd recommend opening a service request to help share logs or, if possible, the DWG files so we can determine what is taking so long. I'd also note that Connectors work on incremental updates, so while the initial conversion may take some time, future incremental updates should generally be much faster.
CC: Don H. Fu
Ok, where do I open a service request?
Please follow the Submit Service Request form: www.bentley.com/.../support
Hi Conradhttps://connect.bentley.com/then scroll down to New Service Request
Also note that you are running this on our "web service" which will sit in a queue for each connection. There is a local synchroniser which will use your machines processing and connection to process the files. There will be no queue, and the performance will be dependent upon your machine processing / ram / internet speed (there are some settings to modify the performance)
