Hi,Do we have possibilities to use connector for Plant3D models? Any other possible ways?Thanks
Hi Deepak,
I think you probably already received this answer from someone else, but I'll repeat it here incase anyone else reads this question.
We do not currently have a specific connector for Plant 3D. At this time, I would suggest to try to first import the Plant 3D models into Navisworks and then use the Navisworks connector.
Tim
Answer Verified By: Deepak Singh
Hi Tim,Thanks for the details on the request.The suggested possibility has been tested? In one of the wiki, I can see the list of tested output from Navisworks using Navisworks connector but for Plant3D it was not listed there.Thank you so much for your help.Regards | Deepak Singh
Not for Plant 3D because we don't have access to the application and we have yet to receive any files to test this with. If you could provide us with some Navisworks models that were created by importing from Plant 3D, that would be helpful.
If you do not need business data in iTwin, you can try AutoCAD connector, which should bring in geometry created from Plant3d & PID.
