I attached local Geolocated Reality Mesh to a dgn file following the wiki (Attaching local Geolocated Reality Mesh - Synchronization Wiki - iTwin Services - Bentley Communities), then I use iTwin Snapshot to convert this dgn file with into iModel snapshot, but I cant's see the attached reality mesh in the imodel snapshot. Is it possible to do this with Twin Snapshot or there is something I should pay attention to?
Thank you!
iModel snapshot doesn't support that workflow. In a online iModel the reality mesh would be convert into a web ready reality mesh in our ContextShare platform and made accessible to the iTwin Viewer. The DGN data is stored in the iModel and the Reality Mesh is stored in ContextShare and the two are shown together in the iTwin Viewer.I am going to assume that you are developing your own iTwin viewer in which case you can publish the reality data in another tile based format (for e.g. Cesium ION) and reference the data in that method. https://www.itwinjs.org/learning/display/tiles/
Answer Verified By: Liu Jian
