Hi,I am getting this Alert dialog again and again. I have click on Confirm and retry the Sync but ended but with same Alert dialog,
I checked the FAQ but the suggested solution is not helping to move on. Anything else, I can try to move on?Thank youRegards | Deepak Singh
Hi Deepak,Is this issue resolved or Are you still facing the same issue?
Hi HarshalI still have the same concern. I just used online connector for the time being to move on.I am not sure, but it looks like application is trying to reach some specific internet resource that is possibly blocked by internal IT due to security concern.Regards | Deepak Singh
This would normally go away if you try the fresh sign in. I would suggest clearing all your iTwin Synchronizer entries from the credential manager as explained in the FAQ and try again.
Hi Harshal,I have done the steps mentioned in the FAQ (removing credentials, but still I am having the same issue). I can't move forward and getting the Alert dialog again and again.I need quick assistance on it to make it working. Please help here.Regards | Deepak Singh
Hi Deepak,Can you please email me the logs and screenshot of the browser page that opens up when you accept the conscent? And also send me the screenshot of your credential Manager page after you remove those specified credentials in the FAQ?
