What’s New in Promis.e V8i SELECTseries 8
The Cable Manager has been enhanced to support the following functionality:
We have removed the export to DWG, DXF, and send to printer features from the Project Publisher to make this tool focused upon PDF output. If you need to export to DWG or DXF the Batch Converter Tool supplies this functionality today and can be found in the Output>Plot & Publish task menu.
“C:\Program Files (x86)\Bentley\Promise V8i\Promise\Promise\PromiseStarter.exe" "-W@IEC Default"
Assume we create a folder in the Promis.e Data path: C:\ProgramData\Bentley\promis-e V8i\promise Data\MyFolder
We can use a special variable (such as %data%) to replace it. Then the relative path in URL would be: File:// %data%\MyFolder
Now we support the following variables below:
%datafolder%: This is the Promis.e data folder.
%projectfolder%: This is the folder where your project resides.
%pagefolder%: This is the folder that the active page resides in.
CONNECT integration provides a common environment for comprehensive project delivery. By leveraging a Common Environment you can productively integrate Modeling and documentation workflows across disciplines for projects of any size and complexity. You can easily access, share, and manage all your Data throughout the project and asset lifecycle. You can make better decisions with immediate feedback and clear insight made possible through complete visibility into design and project Performance.
You can now login to Bentley CONNECT and specify a CONNECT project to associate your Promis.e project with. In the New Project or Modify Project dialogs you can browse the list of existing CONNECT projects or create your own. You can find more information on Bentley CONNECT on our website.
We have made an attempt to improve the performance of several features in the software to reduce the negative impact of higher latency networks. We have reduced the number of queries being sent to the project database and cached some data to reduce the chattiness to the project database. A few other types of performance optimizations were also made. The following features have been optimized:
We have improved the database security to meet product security standards. The software now installs a unique security certificate on each machine that is used to encrypt/decrypt the database password.
NOTE: One implication of this change is that each setup.xml will now have a unique certificate thumbprint ID that is only valid for the certificate on that one machine. This means you won’t be able to copy the setup.xml from one machine to another. If you want to be able to do that you can obtain your own certificate from a certificate authority and have it created so that it can be deployed on multiple machines. You can then edit the thumbprint ID in the setup.xml to use the new certificate that you obtain.
See the Create a security certificate for password encryption article.
This release now properly recognizes an academic license and displays appropriate notices such as, “For Academic Use Only” in prints and reports.
Readme
Resolved Issues
How to download the promis.e software
Updating and Upgrading Promis.e
