Bentley Raceway and Cable Management CONNECT Edition
The Bentley Raceway and Cable Management product team is pleased to announce the availability of Bentley Raceway and Cable Management CONNECT Edition x64 (10.00.00.127) on Software Downloads.
Download
If you would like the setup executable of Bentley Raceway and Cable Management CONNECT Edition x64, please follow these steps to download it from Fulfillment Center:
  1. Sign in to connect.bentley.com
  2. Choose Software Downloads from "My Support" section
  3. Select the Brand Promis.e and then select the Generation of CONNECT Edition
  4. Download the latest release by clicking on the arrow to expand the selection and then on Bentley Raceway and Cable Management CONNECT Edition x64 version 10.00.00.127
Important installation requirements and notices are found in the Readme
Please refer to the following link for the Resolved Issues in Bentley Raceway and Cable Management CONNECT Edition.  Also, be sure to visit the Promis.e forum on Bentley Communities to keep up to date with the latest information on Blogs, Wiki's, Announcements and Support Forums.
What's New Highlights
New Workflow-Focused User Interface
BRCM tools are now organized into eight tabs; each one focused on different workflow steps. Each section contains only tools required to complete the workflow. The goal of this enhancement was to increase user’s productivity by focusing only on tools relevant to a specific workflow.
New Configuration System
In line with the MicroStation CONNECT configuration system, BRCM is now taking advantage of the workspace> workset configuration system.
3D Cables Visualization
After cables are routed through raceways, Create 3D Cable option can be used to visualize cables inside a raceway system. Visualized cables cannot be edited.
Cable bend radius is the same as cable tray bend radius, and the default option cannot be changed at this time. Additional enhancements (making sure that cable maximum bend radius is smaller than cable tray bend radius) are work in progress.
Converting Arch and Circle into a Raceway
Users can now convert aches, circles and other complex shapes into a raceway system. In previous versions, BRCM could only convert straight lines into a raceway. Standard Raceway generator function is used to convert any shape into a raceway.
Clash Detection Module in BRCM
Users can now take advantage of Clash Detection module at no additional charge. Clash detection tools are available from Modeling>Analyze or Drawing>Analyze menus.
Support for Citrix Environment
BRCM can now be configured to work in a Citrix environment.
