Bentley Raceway and Cable Management CONNECT Update 3
The Bentley Raceway and Cable Management product team is pleased to announce the availability of Bentley Raceway and Cable Management (10.03.00.25) on Software Downloads.
Download
If you would like the setup executable of Bentley Raceway and Cable Management CONNECT Edition x64, please follow these steps to download it from Fulfillment Center:
  1. Sign in to connect.bentley.com
  2. Choose Software Downloads from "My Support" section
  3. Select the Brand Promis.e and press the Apply button.
  4. Locate the "Bentley Raceway and Cable Management" tile and select the Get Software link.
  5. Select the Generation of CONNECT Edition and click the Apply button.
  6. Download the latest release by clicking on the download button for Bentley Raceway and Cable Management CONNECT Edition x64 version 10.03.00.25
Important installation requirements and notices are found in the Read me
Please refer to the following link for the Resolved Issues in Bentley Raceway and Cable Management CONNECT Edition Update 3.  Also, be sure to visit the Promis.e forum on Bentley Communities to keep up to date with the latest information on Blogs, Wiki's, Announcements and Support Forums.
What's New Highlights
Components Center (Technical Preview)
Components Center is a cloud-based digital component library and catalog management service. It allows users to efficiently manage their digital component libraries while providing their designers with approved, proprietary components as well as manufacturer's content via subscriptions.
Components Center users can create their own organization catalogs and populate them with content provided by Bentley or upload custom content to share among all their users.
Both Raceway and Equipment can be downloaded from Components Center. The first time a raceway is routed or an equipment placed, the catalog will be downloaded to a local cache folder making it faster to insert the next time you route raceway or place equipment.
Enhanced Cable Routing
  • When routing cables the software will now consider the minimum bend radius of the cable. You can specify the minimum bend radius in the Options > Cable Data > Cable Types dialog.
  • After visualizing routed cables you can now update the calculated lengths to include the bend radius.
Enhanced i-models
We now include raceway cable fill information in i-models so that the information can be reviewed in Navigator.
Flexible Equipment Level Assignment
You now have the ability to set the same level for equipment and equipment IDs in the Options > CAD Standards > Levels dialog.
Enhanced Raceway Labeling
You can now display the position of any raceway as defined in the grids of the Duct Bank or Raceway Router dialogs in Raceway ID labels.  i.e. "A1" would represent a position defined by column "A" and row "1" in the routing dialog.
The following tools now allow you to include the "Position" attribute in the ID Settings:
  • Duct Bank Router
  • Raceway Router
  • Raceway IDs
New Place Equipment API
This new API allows you to specify an equipment name and position to automate the placement of equipment.
public Equipment. PlaceStatus Place(
        string eqiupmentID,
        double x,
        double y,
        double z
Consistent Project/WorkSet Creation
When creating a new project in the Project Manager the software will now create the DGN folder and place the rcmProject.xml file in this folder.
