Trying to create a multi-tag datasheet and have followed the online training and help files.
I have named the vertical range of unmerged cells as _TAG_NO
When I try and allocate more than one tag I get an error message saying the sheet does not have multiple cells defined for tag numbers
What am I missing?
Hi Kevin, what product and version is this related to?
Instrument & Wiring version 8.11.10.182
I have the same problem, somebody have some procedure How to use multi tags in Data Sheets?
Enrique,
When you build the multi-tag datasheet make sure the following:
1. The multi-tag cells are vertical and are not merged cells.
2. Select the vertical rows and assign them the name with a double underscore and then the name such as __TAG_NO.
Try these two options should resolve the issue. For an example search in the base project standards datasheet template for Thermocouple and Thermowells.xls. This is one example we ship of a multi-tag datasheet.
If we need to we can take this offline and setup a meeting to review this.
Thanks so much,
Brandon Moberg
