ARAMCO Excel file to create a Title block to export in Promis-e v8i -> write to title block failed!
We asked a company for their "Title Block" for a project we have to do for them, and they mailed us this software: AUTO-SACS 6.1...
After running the installer i don't understand what to do, i don't even know what this software is and if it is a plugin for promis-e v8i... someone had a similar experience or can help me understand what i have to do?
EDIT:
Changed the title because the question changed. :)
As i mentioned in the last post, i found in the package a folder named "Microstation ARAMCO Tools", in which there was an Excel file (that ask for marco activation when opened) to fill with many information about the "title block" (revision, name, type,...), and a button to "create drawing" (that shoud create a .dgn file with the title block and the information i wrote in the excel file before).
After hitting the button, the script starts and open promis-e, and i see a preview of the correct "title block" but after that, seems like he can't create it (it just create it partially) and in the report file it says:"write to title block failed".
This file should be a standard file for ARAMCO to create the Title Block, so i hope someone can help me this time, or give me a clue!
Promis-e v8i is installed in a pc with Windows Vista
Thank you,
Daniele
  • SACS is a completely separate Bentley software package that has nothing to do with promis.e. Here is its product page: www.bentley.com/.../SACS
    I have no idea why they would have sent you that. There is no built in interoperability between the two products that I am aware of. Typically a titleblock would come as a single DGN or DWG file that you would bring into the promis.e Titleblock wizard to add the promis.e intelligence to the CAD graphics of the titleblock for use with promis.e.
  • Please refer to the new information in the first post for more detailed information about my question, thank you!
    I'm investigating this matter because i am really confused. :)
    Could it be that this software contain the possibility to compile an excel table used to populate a particular "title block", that i assume they must give us?
  • You can't populate a titleblock in promis.e using a spreadsheet. I have no idea why your end user thought you needed a copy of the SACS software which, from what I can tell on the product page, is software for designing offshore platforms, not anything electrical. I suggest that you contact your end user and ask them why they thought you needed this and repeat that you are requesting a copy of their titleblock, which would typically be a single DGN file of the graphics and texts that make up their company titleblock.
    Actually looks like in the folder there was an annidiated folder with an excel that once filled, and after hitting the button inside, should create a dgn file with all the information for the title block.
    I mean that this excel should create the title block itself, but it give me error when he try to create the title block and i end up with an incomplete dgn file (there is only a little part of the information and graphic for the block).
    At this rate i think i will have to contact them back, but i wanted to update the thread to let you know, maybe now it's more clear.
  • I have never heard of ARAMCO, but if you say it is an add-on to MicroStation, then it probably detected that promis.e has a built in MicroStation engine and is trying to run its ARAMCO function, but since it is not installed, it fails. There is no way that you can use an excel file to generate a titleblock in promis.e. If some other software does do that, then you would need to use that software to make the excel file create a DGN file with a complete titleblock on it, then import that complete DGN file into promis.e titlblock Wizard to add the items promis.e needs.
